steering wheel shakes at 55mph
Old 09-24-2011, 07:37 AM
Save the manuals!
wssix99's Avatar
Originally Posted by Bjorn20
wheel bearings do not cause vibrations
worn front end parts do not cause vibrations
alignments have nothing to do with vibrations
If you have had a vibration since day one and just got new tires, I would suspect that those wheels are bent. But either way steering wheel vibrations are normally from a tire/wheel out of balance.
vibration while braking at high speeds is a warped rotor. Usually the front rotors. The rear brakes can get warped rotors too, they are just harder to diagnose, depending on how the parking brake is setup.
More proof we shouldn't believe everything we read on the internet.
Old 09-24-2011, 02:19 PM
Bjorn20's Avatar
^^ Are you saying that I am wrong and that wheel bearings, alignments, loose tie rods and ball joints, and worn bushings cause vibrations?
That's fine, just continue spending hundreds/thousands of dollars replacing every steering/suspension component on the vehicle and pray that it fixes it.
Old 09-24-2011, 03:22 PM
02ws.sik's Avatar
Well asshat the front end alignment fixed it the total cost at the end was 102 dollars so you are wrong. Quit trolling on forums.
Old 09-25-2011, 08:27 AM
Save the manuals!
wssix99's Avatar
I would think a bad bearing would also contribute a lot to that. How did you replace the bearing for $100? Inside deal?
Old 09-25-2011, 09:02 AM
02ws.sik's Avatar
No the alignment and bearing was 102 dollars total cousins works there hes cool i gave him a 50 for all the help.
Quick Reply: steering wheel shakes at 55mph
