Locating a ground wire...............
Old 09-26-2011, 05:47 PM
LS6427's Avatar
Default Locating a ground wire...............
Does anyone know exactly where, on the Drivers side head, ground wire G112 is attached.....I need to check to make sure its tight. But I'll just be reaching back there blind with my hand.
Its an 02 sensor related ground wire coming off the PCM harness.
Old 09-26-2011, 06:15 PM
JaYZeig's Avatar
hope this helps
JaYZeig's Avatar
ps, sorry its so big
Old 09-26-2011, 06:29 PM
LS6427's Avatar
^^^^ There's two of them back there....huh....ok.
Hell yea, that helps....thanks allot man.......I owe ya.......
Old 09-26-2011, 06:33 PM
cookba's Avatar
good find. i was wondering where this was as well. THANKS
Old 09-26-2011, 06:36 PM
cookba's Avatar
PS, JaYZeig, where can i get schematics like these?
Old 09-26-2011, 06:38 PM
LS6427's Avatar
Yea man......where are these little gems located too....lol
I have other items I need to find.
Old 09-26-2011, 06:44 PM
JaYZeig's Avatar
im a tech at a gm dealership and i have (si) service information, unfortunatley i cant give out my user name and password bacuse they can track the different computers that visit, and i dont want to cause any problems.
what else do you need to see?
Old 09-26-2011, 06:56 PM
LS6427's Avatar
Thats cool.
I'm needing to follow both FRONT 02 sensor wires up from the sensors, all the way back to the PCM. I need to check for damaged wires or corrosion at any of the splices.
Thanks.
Old 09-26-2011, 07:10 PM
JaYZeig's Avatar
pcm connector BLUE
HO2S Signal Low Bank 2 Sensor 1
pin 26 tan wire
HO2S Signal Low Bank 1 Sensor 1
pin 29 tan/wht wire
HO2S Signal High Bank 2 Sensor 1
pin 66 ppl wire
HO2S Signal High Bank 1 Sensor 1
pin 69 ppl/wht wire
Old 09-26-2011, 07:13 PM
JaYZeig's Avatar
heres what i found regarding your front o2 sensor wiring
a, tan, ho2 low
b, ppl, ho2 high
c, blk, ground
d ,pink, ign feed
Old 09-26-2011, 07:39 PM
LS6427's Avatar
Cool...thanks....that'll help for sure. Especially since I'm an electrical newbie.
Old 09-26-2011, 08:06 PM
cookba's Avatar
can you show schematics for all grounding points and paths? also routing of the alternators "exciter" wire?
Quick Reply: Locating a ground wire...............
