'02 TA won't start -- common culprits?
After doing some searching and reading, I am kind of getting an idea of what things could cause my '02 WS6 to not want to start, however, I'm not sure how to prioritize the fixes based on my symptoms. So hopefully you all aren't tired of repeating yourselves...any help is appreciated.
I recently bought a 2002 WS6 Trans Am and it started and drove great for a week and a half. Then, it sat all day Friday without firing up (I have another car). Come Saturday, I put the key in the ignition, hear the fuel pump start and all the lights go on, and turn the key...nothing. I'm not hearing any sound from the engine bay/starter, all of the lights just shut off until I release the key.
Thinking it was the battery, I took it to AutoZone for a checkup/charge, and the guy says it's a bad battery, but it's on warranty, so he hands me a brand spankin' new one. This morning I pop the new battery in and still nothing.
So:
- Was running fine last week
- Lights and accessories work with key in the "Run" position
- Battery is brand new
- Fuel pump is running
- NO "Security" light
- When trying to start, I can hear all of the electrical shut off, but nothing from the starter
- The contact on the positive cable at the battery is a little corroded
Obviously I will try and clean up the corrosion on the cable first, but if there's anything else I can try first cheaply and easily while I'm in there, I'm all ears!
Thanks guys.
So:
Thanks guys.
Well, I literally got it from AutoZone last night, brand new. I asked the guy if it was "ready to go" -- to which he responded yes, it was. Should I have to charge up a brand new battery? I can certainly take it back in and have them give it some juice if that is the case.
Thanks for the quick replies. I will try a few things today and report back. Guess I should get my hands on a meter, eh?
Update: So the battery is fine, the cables are corrosion-free and have good connection. (Well, up by the battery, that is. I can't effing get to it down where the starter is.) I swapped in some of the fan relays in for the starter relay (but not the ignition relay) also to no avail. Still simply no sign that the starter even wants to attempt anything at all.
Side rant: I called for a tow last night (I'm in Seattle) to get the car to a shop, because I have neither the time nor tools to do anything further. After waiting AN HOUR for the damn guy, I called the dispatcher saying I had s--- to do, to which he responded that he is still fifteen minutes away. Please note that I can WALK into downtown Seattle from where I live given an hour and fifteen minutes. I said f--- it and so it's still sitting today. I'll try a different company.
So, should I try the relays again? Have a go at the ignition switch in the steering column? I have no idea what I'd be doing there, but I'm sure I can find info in here on how to do it. Or is it pretty likely to be that the starter is toast? It's not even clicking, so I'm hesitant to say that it's getting the signal but just totally incapacitated...
It could be the vats on your car acting up research that. Wait is your car a 6 speed. It can be your clutch position sensor came out od adjustment. It could also be your starter going out. Tap on it with a hammer while you get someone to start the car.
The car is lowered pretty significantly, but I guess I could jack it up to see if I could get at the starter with a hammer.
I have the exact same prioblem from time to time. I even tuned out VATS with my HPTuners and it still has the same issue. I dont think it is something with the clutch position because one time it happened and I had my laptop w/hptuners up and it would not even let me connect to the VCM. I also messed with the starter/ignition relay with no luck.
the clutch sensor should be on on your pedal assembly. the one on top is your clutch anticipation switch and the one underneath is the clutch sensor for the starter
I appreciate the help guys, it's a lot more useful than a shop telling me I need a new engine or something stupid like that. (There's a shop nearby that might suggest something close. I don't go there.)
It will have a push button on the head of the sensor that the clutch pedal arm pushes down and engages. To adjust it you simply have to unplug the wiring harness boot from the back and screw it in or out from the pedal arm.
Doing some more research on the site, I think I have it down to either the clutch position sensor or the ignition switch, just based on some of the symptoms that other guys have had. I don't think it's the VATS, since I'm getting gauges lighting up, etc., but no Security light.
I will tackle those this weekend probably and keep you posted. Getting to the ignition switch looks like kind of a PITA, albeit a doable PITA. Is there a way to check the ignition switch before replacing it (with a meter or test light or something) to check that it's good/bad?
Again, thanks so much for those who have contributed. I would have been so lost otherwise.
Check fuel pump pressure. Do you have gas in the car? Pull a spark plug wire, hook up an old plug and verify if you have spark. When did you last change out the fuel filter?
As an update: I figured I would go and check out the clutch sensor(s?), since it seemed like the easiest thing to do...and there has been mentioned that there's one "above" and "below," however I can only really find one! It's a button on a white plastic threaded housing -- the button is depressed when the clutch is all the way OUT (foot off). (Actually it's a little loose, and doesn't get depressed fully, but most of the way.) Is that the so-called "clutch anticipation" sensor? For the life of me, I can't find one that gets depressed by the clutch pedal when it is all the way in.
Is there any reason to believe the other has been removed? After thinking about it for a while, I did recall the thing almost starting up when my foot wasn't on the clutch; I had grown used to the auto in my Z28, so I got the ol' lurch as the starter went to engage while the car was parked in gear. (Oops.) That was back when I first acquired the car; it started fine for a while after that.
So, am I more likely looking at an ignition switch or starter solenoid? I'm not so excited about jacking the car up and getting underneath to get at the starter parts. (Correct me before I make a mistake: the starter is on the passenger side near the firewall/flywheel side of the engine?)
PS: I have a couple pictures from underneath the dash on my phone, but it's synching up to my computer right now and is otherwise useless at the moment.
Sorry. My fault. Read it quickly and thought you were saying it was cranking over but not starting.
I have a 99 6 speed and I just tried a whole bunch of things to see when the car would/would not start.
Basically the only SINGLE thing that would cause my car to not start was if I did not push in the clutch pedal. I believe there is a switch on the top of the clutch assembly (cruise control) and bottom of pedal (your problem). Ensure you don't have any battery issues and my main guess would be some issue w/ your clutch pedal switch.
I've had problems in the past w/ the top CC switch not working and back then my car started fine SO must be a lower switch issue. Check/test/bypass that switch and see if your car starts.
Every once in a while I will go to start my car and I will have to press the clutch pedal to the floor a little harder for it to engage the starter. If that doesn't help you will need to tap the starter solenoid box with a wooden handle and try again. If that's too much hassle for you then I would suggest buying a new starter.
The same thing happened to my dad's 01 Z06. He got tired of having to reach under the car so he just replaved the starter... no issues anymore.
