Lighting issue in a 99 camaro
Alright guys maybe you can help me out. I turned on the car about a month ago and none of my headlights were working! GREAT!!!! so today after over a month i finally took everything apart! thru away all the HID bull **** and bought new stock bulbs. After everything my headlights still dont work! my fog lights worked for 10 minutes turned the car off and then back on and bye bye fogs!
i checked the fuses none seem to be burnt. replaced the two lh/rh headlights fuses with new 25 amp fuses! also the fog light switch now does not even turn on!!
What do you guys recommend?
Alright guys i need your help again.....
So now that my headlights are working and replaced the headlight switch, the fog lights dont come on! Not even the light on the switch that tells you that they are on, but if i activate the alarm with the button pushed in as if it was on they turn on....... Already checked fuses, relays and replaced it with a used switch! could it be possible that i have yet again bought a non functioning fog switch?
check the "dimmer" fuse i drove around for about a month until i decided to check all my fuses while i was there and the dimmer was burnt. replaced it and good to go
