squeeky belts after ls6 manifold swap
Old 09-29-2011, 10:53 AM
Chaos07's Avatar
Default squeeky belts after ls6 manifold swap
Ok guys so I take my car for a test ride and after a few miles the belts start to squeak. I do believe a coolant hose wasn't tightinedwith the clamp so I put it bck on. N the squeek goes away. Start it up this morning and its squeeking again. Eventually it goes away at idle but when I press the pedal it will squeek again. Help me out.
Old 09-29-2011, 11:26 AM
Z/YA's Avatar
If you got coolent on the belt it is near impossible to get it clean, I recomend you get a new belt and that should fix your problems
Old 09-29-2011, 01:58 PM
Chaos07's Avatar
hmmm no wonder it keeps squeeking after sitting for a while, ill replace both belts soon.
Old 10-20-2011, 03:43 PM
Chaos07's Avatar
well after a week, i guess the radiator was leaning to far back and the radiator hose was getting cut but the ps pulley and start spraying coolant everywhere. now my belts squeek all the time and usually while im driving they squeek and wont while its idle
