Can you look at something on your car for me?
Old 09-30-2011, 01:57 PM
180ls1's Avatar
Default Can you look at something on your car for me?
Well the car has been running a little rough and i want to do the idle relearn so i have searched and ran across this a few times but for the life of me i cant find the PCM BATT fuse!!! Am i overlooking it or is it something the 98 cars dont have? I can find the pcm IGN fuse just fine.
PCM Reset
Turn key on, don't start car
Pull PCM BATT and PCM IGN fuses in engine compartment
Wait 5-10 min
Turn ignition off
Replace fuses
If someone could run out to their can and look real quick i would really appreciate it
Old 09-30-2011, 10:32 PM
LS6427's Avatar
PCM Reset
Wait 5-10 min
Turn ignition off
Replace fuses
Its a tad more involved than that. Here:
Reset PCM:
-Insert key into ignition and turn to the "On" position but, DO NOT START THE ENGINE.
-Pop open the engine fuse block box cover and remove the two 10amp fuses from position numbers 16 & 23.
-Your DIC will now display "check" messages for ABS, etc...
-Turn ignition to the "Off" position.
-Re-insert both 10amp fuses for positions 16 & 23.
-Start your engine
-Allow engine coolant temperature to reach a minimum of 176 degrees F and run at this minimum temperature for at least 5 minutes.
-Shut down engine
-Let rest for a minimum of 30 seconds.
-Restart engine - check for DIC error codes (there should be none).
-Drive car for a minimum of 30 miles at varying rpm settings and speeds. PCM will now re-learn and adjust for the new air flow and air temperature at the intake.
Perform the following procedure to return the learned idle to the correct position:
Automatic Transmission:
1 Turn off the ignition
2 Restore the PCM battery feed
3 Turn Off the AC controls
4 Set the parking brake and block the drive wheels
5 Start the engine
6 Allow the engine coolant temperature to reach 176 degrees F
7 Shift the transmission selector into the drive range
8 Allow the engine to idle for 5 minutes
9 Turn on the AC controls (Omit for 2000-02 model)
10 Allow the engine to idle for 5 minutes (Omit for 2000-02 model)
11 Shift the transmission selector into Park
12 Allow the engine to idle for 5 minutes (Omit for 2000-02 model)
13 Turn off the AC controls (Omit for 2000-02 model)
14 Allow the engine to idle for 5 minutes
15 Turn off the engine for 15 seconds
Manual Transmission:
1 Turn Off the ignition
5 Transmission in neutral
6 Start the engine
7 Allow the engine coolant temperature to reach 176 degrees F
8 Turn on the AC controls (Omit for 2000-02 model)
9 Allow the engine to idle for 5 minutes (Omit for 2000-02 model)
10 Turn off the AC controls (Omit for 2000-02 model)
11 Allow the engine to idle for 5 minutes
12 Turn off the engine for 15 seconds
Old 10-01-2011, 10:45 PM
TruBloodTransAm's Avatar
^good info
