ac and heat only blows out defrost vent now
Old 10-02-2011, 08:12 PM
Ws6Dnero's Avatar
Default ac and heat only blows out defrost vent now
Why is my ac and heat only blowing out the defrost vent now? when i turn the **** it doesnt switch vents
Old 10-02-2011, 08:28 PM
Ws6Dnero's Avatar
any clues or hints to this? someone told me i may need a new ac control unit
Old 10-02-2011, 08:31 PM
Undertow74's Avatar
sounds like the vaccuum lines came off. pull out the control unit and make sure everything is hooked up. It defaults to defrost for saftey reasons so you can see out your windshiled.
Old 10-02-2011, 08:45 PM
It'llrun's Avatar
I concur... Vacuum would be my 1st check.
Old 10-03-2011, 12:32 AM
Ws6Dnero's Avatar
Is there a vacuum lines that runs down the torque arm then stops?
Old 10-03-2011, 10:18 AM
mai krod's Avatar
the vacuum lines in your dash... not the ones on your motor
Old 10-03-2011, 06:04 PM
97transamLTX's Avatar
Theres also a check valve for the vacuum lines right beside the pcm that can cause that problem.
Quick Reply: ac and heat only blows out defrost vent now
