rear end grinding
rear end grinding
I just bought a 02 FB ta ws6 I just got the clutch replaced and I'm just noticing that when I do slow turns to the left I get a grinding sound I'm hoping it just needs a drain and a lube job its been sitting for a year and It doesn't make ne noises when driving normally just when info slow turns ie when parking it sounds real nasty and its embarrassing ne advice on this???? Thanks in advance
Mine did the same thing when I bought it, the rear end leaks from the cover over time and when the gear lube gets low the posi track clutches chatter. I replaced my cover with an aluminum one and added new gear lube and it got ALOT better, but it still chatters sometimes on tight turns, just the nature of the beast I guess.
