car dies at WOT
Old 10-22-2011, 03:13 PM
dw1998ls1's Avatar
Default car dies at WOT
i have a 98 z28 and it has been cutting out and dying when i get in it all the way @ around 62-6500 rpm. put the car in neutral and it fires right back up with no problems also runs fine as long as i dont get in the gas pedal. anyone have any suggestions thanks.
Old 10-22-2011, 03:33 PM
Ironembraced's Avatar
What mods have you done? Sounds like you might be running lean.
Old 10-22-2011, 03:41 PM
dw1998ls1's Avatar
cam,full exhaust,lid,programed from texas speed, thats about it nothing major. it just started doing it recently.
Old 10-22-2011, 03:43 PM
dw1998ls1's Avatar
Old 10-22-2011, 03:44 PM
Is that when your WOT problems started? How long are you running at WOT before it dies?
What injectors are you running (and what duty cycle % are you running them at?) what size cam, how much estimated horsepower?
If I had to take a guess, I'd say it could possibly be dirty injectors or a dying fuel pump or clogged fuel system. But I am just completely guessing.
But we need alot more details to really be any help.
Old 10-22-2011, 03:50 PM
dw1998ls1's Avatar
im not real mechanic savvy but when i get home this evening ill give you all the specs i have on the car it put up in a file at the house. the horsepower dyno was 385 done when they tuned the car at texas speed that was about 3 years ago and it just recently started acting up a few weeks ago. it runs fine as long as i stay out of the gas
Old 10-22-2011, 03:55 PM
dw1998ls1's Avatar
also as soon as it hit around 62-6500 rpm it cuts and dies im wondering if it might be the fuel pump?
Old 10-22-2011, 03:56 PM
It could be...but it could also be as simple as just needing a treatment of Seafoam.
Old 10-22-2011, 04:05 PM
dw1998ls1's Avatar
Thanks ill give it a shot
Old 10-22-2011, 04:08 PM
Just try to go easy on it until you find the issue. If you get detonation, that could ruin your day.
Old 10-22-2011, 10:02 PM
Camaropar's Avatar
Fuel pump, people should be saying this right away considering how bad the OE design is. Get yourself a walbro 255
Old 10-22-2011, 10:14 PM
So you already ruled out the injectors without even looking at it?
But yeah I guess it is safer to just replace it now regardless.
Old 10-23-2011, 12:35 AM
mrmckeehan's Avatar
sounds exactly like my problem I am having but mine does not cut off. mine throws the service engine light then bogs down. I have no clue what it is.
Old 10-23-2011, 12:48 AM
Check your throttle position sensor and also check your fuel pressure.
Have you pulled your codes yet?
Old 10-23-2011, 01:04 AM
slowpoke96z28's Avatar
if you're gonna go the shotgun route, i'd do a fuel filter b4 i did a fuel pump. a dirty filter may very well manifest itself like this, and its the cheapest thing you can do. i'd probably pull a plug or two if you can do it right after it happens. the plugs can tell all...
Old 10-23-2011, 01:43 AM
myk
myk's Avatar
Fuel system pressure test is the best thing to do. These pumps go out all of the time. Rent or buy a fuel pressure gauge and hook it up to the rails and see what you've got during start-up, idle, throttle and how it "leaks down" once the motor is off...
Old 10-23-2011, 02:24 AM
NVUSZ28's Avatar
If you don't have a upgraded FP, this was my suggestion.
Old 10-23-2011, 04:10 AM
Camaropar's Avatar
Yes, I did. Fuel injectors are not it as they'd be a problem at lower RPMs/loads.
I'm not saying blindly replace the fuel pump, obviously a fuel pressure test is in order but sure sounds like it.
Old 10-23-2011, 06:03 AM
dw1998ls1's Avatar
fuel psi stays around 48-50 and holds when i kill the car. i pulled two codes they were p0135,&po155.
Old 10-23-2011, 08:07 AM
those are o2 codes. not gonna cause this symptom. fwiw, you need to see the fuel pressure when the problem occurs. whats THAT number?
Quick Reply: car dies at WOT
