Grinding noise when trying to start...flywheel? - LS1TECH
Thread Tools Search this Thread
Old 10-25-2011, 09:45 PM   #1
Default Grinding noise when trying to start...flywheel?
Last week I was driving home in 2002 WS6 with 113k miles and heard what I thought to be an exhaust leak out of nowhere. I revved the engine and it got louder but at idle seemed to disappear. I have a cutout so that may have covered it up. I just got two new cats so I thought maybe the bolts were loose.
I parked it and let it sit and the next day I get underneath to check the cats and everything seemed fine. So I try to start it and hear this really loud grinding noise and the engine doesn't even try to turn over. I do some searching online and read it could be the starter, bad ground, or battery not putting out enough amps.
I get a brand new (not reman) starter today and hear the same noise. Check the ground and wires and everything seems ok. I take the <2 year old battery to Autozone and they say it's fine. I then check the inspection cover and look at the flexplate and notice a small crack.
TONY206 is offline   Reply With Quote
Old 10-25-2011, 09:59 PM   #2
Automatic btw.
Old 10-25-2011, 10:53 PM   #3
Well, found a video and this sound could very well be it.
http://www.youtube.com/watch?v=wtK_I...layer_embedded
Old 10-26-2011, 02:50 PM   #4
macknmikey's Avatar
torque converter bolts tight?
nvm didnt read your full post just looked at the video..
macknmikey is offline   Reply With Quote
Old 11-11-2011, 11:31 AM   #5
Related Topics
Thread Thread Starter Forum Replies Last Post
rebuilt opti, orange spark... is this a problem? Numba20 LT1-LT4 Modifications 1 04-06-2013 11:32 AM
Voltage Issue? DopeFedZ Conversions & Hybrids 4 06-10-2010 08:06 AM
Interesting problem with my 97 Formula formula137292 Pontiac Firebird 1967-2002 3 04-30-2010 01:54 PM
lt1 starter shim problems? multmigs General Maintenance & Repairs 0 05-02-2009 07:19 PM
First P0343, fixed it, now P0300 - could it be broken lifter? Pekka_Perkeles Generation III Internal Engine 1 05-14-2007 07:16 AM
Tags
clunks, engine, flywheel, griding, grind, grinding, intermittent, loud, ls1tech, noise, sound, squeaky, start, starting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
