Trans Am headlights.......
Old 10-26-2011, 11:00 PM
jarheadtex's Avatar
Default Trans Am headlights.......
My left headlight goes up and down 5 times before it stops in the up position. The right one catches on the hood and opens half way. Any ideas?
Old 10-27-2011, 09:16 AM
SOMbitch's Avatar
Stripped gears. Already done the "Free headlight fix" to the passenger side at the bottom of the page but replacing the gear is a more permanent fix >>>> http://www.bfranker.badz28.com/headl....htm#FreeGuide
This may be helpful too>>> http://www.youtube.com/watch?v=HuolISwRJJg
There are also some other vendors who sell the gears if you google "trans am headlight fix" if you want the permanent fix ..
Old 10-27-2011, 05:43 PM
jarheadtex's Avatar
Thanks!
Old 10-27-2011, 08:00 PM
JaYZeig's Avatar
i had my headlight catch on the hood also, crushed the damn fiberglass too
i had to adjust the hood and the headlight away from eachother..probably only needed to adjust the headlight though.
Old 10-27-2011, 09:48 PM
great421's Avatar
Check the stickys in the Firebird section.
Lots of good stuff there.
