What Causes the ABS INOP Light To Go On?
Old 10-27-2011, 12:00 AM
Xtreme57's Avatar
Default What Causes the ABS INOP Light To Go On?
My ABS INOP light has been on for months. I think it came on during one of the last few winters and hasn't gone off since. Does this mean my ABS isn't functioning? What can cause this and how can I fix it????
Thanks!
Old 10-27-2011, 01:04 AM
slowpoke96z28's Avatar
yep, it wont work if the light is on. if you dont like abs, you dont have to do anything. typical causes are a front hub going bad or pinched/burned wires at the back. another thing is a bad power or ground. need a real scan tool to pull abs codes iirc. 50 buck code grabber wont do the trick here.
Old 10-27-2011, 02:49 AM
myk
myk's Avatar
Check your rear wheel speed sensors too. Dirty sensors can mess with the recultor wheel and make your car think it has a problem. If it's a front wheel sensor issue you'll have to replace the entire hub. Worst case scenario is your ABS module is going out...
Old 10-27-2011, 07:59 AM
Save the manuals!
wssix99's Avatar
The actual light on means that an ABS code has been set. This is bad. As slowpoke pointed out, you'll need to get a hold of a premium scanner to read the codes. Once you have that, the problem should be easy to figure out.
Old 10-27-2011, 11:42 PM
Xtreme57's Avatar
Is there a diagram or pic where I can figure out just what these sensors look like so I know what I'm inspecting?
So this light going off can actually mean multiple codes have been tripped?
Old 10-28-2011, 12:56 AM
http://www.acdelcotechconnect.com/html/tss_tech_esi.jsp
3 day subscription. $20.00 lol
Old 10-28-2011, 07:03 AM
DAVE00's Avatar
You need to update or add a signature letting us know what car/mods you have as there is a big difference in the way codes are scanned for ABS from the OBD1 to OBDII and LT1 to LS1 series. Also in the way the ABS system is setup from a 3 channel to 4 channel. More information is needed.
Old 10-28-2011, 08:18 AM
stingrayj's Avatar
I had this happen on my '95 Camaro. From what I recall it was a bad seal on an abs sensor. Water was getting inside the sensor and causing a short. Replaced the sensor and all was good.
All of the work was done at my local Chevy stealership...which is no longer in business...so I can't really help you out with any repair tips.
Old 10-28-2011, 10:26 AM
Save the manuals!
wssix99's Avatar
Bingo - but odds are the code(s) will tell you exactly where the problem is. Check the codes before you check the sensors. The problem can have a number of different causes.
Old 10-28-2011, 03:04 PM
AmarilloWS6's Avatar
Mine was just the ground, it was really loose, I tightened it and now it's perfect
Old 10-28-2011, 03:56 PM
ccrook19's Avatar
Dont guess, plug it into a scanner and check the ABS code.. it will most likely be a speed sensor..
Old 09-03-2013, 02:37 PM
brando98z's Avatar
Can someone post a pic of the rear speed sensor location and detailed removal instructions . The car im takeing it out of is 98z28 without traction control . Having A problem with abs inop and brake light . About once a month they will both shut off for like 5 minutes already changed font rotors and pads rear pads and front driverside calliper cause I needed it . After I changed front rotors and pads lights went off for like a month now same thing both back on. Hoping maybe its rear speed sensor . I know I should scan it but dont have the bucks for exspensive abs scanner . Car seems to stop pretty good. Any insight to this issue is appreciated .
Quick Reply: What Causes the ABS INOP Light To Go On?
