turn signal not flashing
Old 10-29-2011, 02:09 PM
trans665's Avatar
Default turn signal not flashing
the car right hand turn signal stays lit, when you flip the switch...both front and rear light lit up and stay on...but do not flash...any help plese i would like to knoe if this is a easy fix beore i trade.
Old 10-29-2011, 11:04 PM
puddingmmmmmmmm's Avatar
Sounds like it's the flasher. Pretty simple to replace.
http://shbox.com/1/flashers.jpg
Old 10-30-2011, 08:23 AM
JamRWS6's Avatar
You have a bulb out. Only if both sides (left and right) have the same behavior do you have a flasher issue. Either one of those are an easy fix.
