No starting, security light on, new battery tonight
Old 10-31-2011, 10:00 PM
HumanNipple's Avatar
Default No starting, security light on, new battery tonight
My car would not start so I replaced my battery since this happened earlier in the week. I just put a brand new battery in not an hour ago and it didn't help. My security light has been on for nearly 2 years with no starting issues. I hear 1 solid click when I turn the key to start all the way pressed. If I leave my key with all accessories on I hear the my fuel pump, some electrical parts of the car buzzing as usual. I swapped the ignition and starter modules, fan and ignition and nothing worked. My alternator was replaced last year. Also I do have a check engine light which was a P0108 I believe. With all this being said do you all think this is related to my starter or the security light, or something else.
Old 10-31-2011, 11:04 PM
Whiteaw57's Avatar
whats the voltage on the battery reading?
Old 10-31-2011, 11:10 PM
i'll have to check tomorrow, i'm off to bed for now.
Old 10-31-2011, 11:11 PM
ybaslo1's Avatar
Well, if your battery is good (Not all new batteries are good), then I would try to tap on your starter with a hammer while a buddy cranks it. You may have two separate issues. If you hear a click (And it is coming from your starter while cranking) you may just have a bad starter.
Also, if you had a bad battery or low voltage, you should hear a bunch of rapid clicks.
Old 11-01-2011, 04:44 AM
BigBadVoodoo Daddy's Avatar
Had a similar problem myself a year ago, its the security light. The chip in the key relates to the passcode 2 system these cars have on them. In the end it was the body control module that needed to be replaced. Stealership did mine for $525!
Old 11-01-2011, 05:43 AM
HASTINGSRJ's Avatar
I agree with the starter as well.
Old 11-01-2011, 07:49 AM
k_garretson23's Avatar
This happened to me it was my vatssystem. I replaced the key cylinder ad all was fine.
Old 11-01-2011, 09:26 PM
My motorcycle alternator just died on me. What the hell did I do to the world!!!!!!!!!!! I have no personal means of transportation now!!!!!!!! OMG wtf did I do to the woorld!!!!!!!!!!!
Old 11-01-2011, 09:54 PM
trey1010's Avatar
Sounds like the vats to me you can fix it by cutting a wire and soldering a specific resistor in to it. I believe there is a sticky somewhere
Old 11-01-2011, 11:28 PM
I got the car to start. I moved the steering column up and down and banged on it, jiggled the key a bunch and it started. I suppose something is wrong in the column
Old 11-02-2011, 10:00 AM
black00ssFL's Avatar
Wiring from key cylinder to BCM for VATS is getting frayed. It will soon completely separate. Get a new key/cylinder asap before you're stuck for good.
Old 11-02-2011, 06:15 PM
SoCal_DarkKnight's Avatar
I did the same thing. I took my multi-meter and got the exact resistance values for my key chip. Then swung over to RadioShack spent 5 bucks on a pair of resistors, soldered them together via the VATS connector plugged it in and Ole Girl fired right up.
Old 11-02-2011, 09:29 PM
bah no starting today, and I haven't gotten parts yet. But on a side note my motorycle is making progress, I found the problem and I need to pick up the part tomorrow
Old 11-02-2011, 09:57 PM
2kblackgtp's Avatar
Had this problem with my car last year. It was the vat's system. I soldered a resistor in to bypass the vats. First find your resistance by checking how many ohms the resistance in your key is with a meter, then go to radio shack and by the proper resistor. under the driver side of the dash when you pull the trim piece off, there will be 2 small wires going into the steering column(one white and one purple IIRC). Those wires are clipped into a harness that has 2 white wires on the other side of it. Unclip the harness, and either cut the white wires back from the harness and solder in the resistor or bend the ends of the resistor and push it into the pin connector slots of the harness. Hope this helps and if you have any questions, pm me and I can try to help. And if you're not sure the vats system is the problem, the dollar you will spend on a couple resistors won't kill you anyway
Old 11-03-2011, 04:56 PM
FiredUpZ28's Avatar
Dude I dunno why your calling them the stealership, thats about average for a NEW BCM + programming. Dont like it? Take it somewhere else.
Old 11-03-2011, 05:06 PM
Z28Z06's Avatar
Slang for Dealership.... most automobile dealerships that I have dealt with tend to hit ya hard in the pocket book. Many among us call them stealerships. I have to agree with the OP.
Old 11-03-2011, 10:02 PM
FiredUpZ28's Avatar
Sorry to hear that. Im a Chevy tech and I gotta tell you, were a pretty honest and upfront group of guys. Some repairs are expensive, and some stuff ends up being free. Sucks to hear about shitty dealerships, i guess its true that they are out there. Anyways, OP a sure fire way to test the high side of the starting system is to jump I believe its 30 and 87a at the starter relay. Just do it for a second. If the car cranks than the starter circuit itself works and the issue is in the control circuit. If you have a theft light on then its likely related to that. Gotta scan the BCM/TDM (forget which one F bodys use for theft) and see what the code is.
Old 11-03-2011, 11:00 PM
Z28Z06's Avatar
My remark was not intended as a judgement of the quality of work at dealerships, but more about price of doing business there. It would actually be nice to go to a specialist (dealership) who knows a certain make of late model cars. Paying list price for OEM parts and the high labor rate keeps me away from dealers. As an enthusiast you probably take pride in what you do, and have good technical knowledge of the brand. Best of luck to you, oh and tell a good dealership story to help change our minds.
Old 11-04-2011, 12:30 AM
Alright so I have read that there may be a frayed wire. That makes sense to me since I wiggled around the column and considering my column is loose that makes sense. Also the resistor in the dash and pretty much everything here makes sense. I probably won't have an update till maybe wednesday next week since i'm out of town. But if anyone has some pics of what they did that would be great, i'm a visual kinda guy. Thanks again everyone!
Old 12-04-2011, 11:23 PM
An update for all you kind folks that helped out. It turned out to not be related to my security light. Even though when I smacked the dash it turned on, it was just luck. My car simply had a bad starter motor.
Quick Reply: No starting, security light on, new battery tonight
