need help asap
Old 11-01-2011, 06:33 PM
mrmckeehan's Avatar
Default need help asap
i have no clue what is going on. i just did a motor swap in my 01 z28 with an ls1 with about 60k less miles. ran great for a month and now when i give it gas, it wants to bog down. the 1st time it started happening, i gave it more gas and the check engine light kicked on then went off then kicked on and went off. so i can't check the light because it has not popped on since.
today my nephew got emitted into the hospital and my brother called me and asked me to bring him and his wife jackets and i went to go take him their jackets and not even a mile away from my house it started. speedometer jumping and if i give it to much gas it wanted to cut out. i have no clue what is going on because like i said, it ran fine for a month.
any advice is helpful and appreciated. here is a video if it shows up if not i will post a link too.
video of the gauge
View My Video
Old 11-01-2011, 06:52 PM
fastassls1maro's Avatar
even though the cel isn't on it should still have codes stored in it. I would start by checking the codes. Sounds like maybe a misfire to me which could be cause by a lot of things.
Old 11-01-2011, 07:01 PM
SOMbitch's Avatar
Check ALL of your grounds
Old 11-01-2011, 11:03 PM
96famaro's Avatar
Location: Weatherford Tx 76085 corner of N. Hwy 51 and 150 Green branch Rd.
You should be able to see the history codes even though the check engine light is off. I sounds like it is electrical issues check your battery cables make sure there tight and clean. The engine grounds, and there are power leads as well where the engine fuses are. Ernest
Old 11-01-2011, 11:19 PM
mrmckeehan's Avatar
i am going to check all grounds tomorrow, i am really hoping to find something since my car is my daily driver.
Old 11-02-2011, 01:35 AM
Ironembraced's Avatar
Looks like something in the fuel system.
Internet mechanics say it could be a plugged catalytic converter as well.
Old 11-02-2011, 03:21 AM
mrmckeehan's Avatar
cats have been punched out.
Old 11-02-2011, 09:20 AM
Save the manuals!
wssix99's Avatar
Do all the needles drop when things go crazy? If so, that could mean low voltage coming from the alternator - that could be related to the bogging.
Also beware of the codes. If you have a sensor, like a dirty MAF, incorrectly commanding to cut fuel, you'll get lean O2 codes - which is a correct condition.
Old 11-02-2011, 10:32 AM
mrmckeehan's Avatar
no, its just the speedometer. only thing that goes crazy.
Old 11-02-2011, 11:27 AM
Jr.Samples's Avatar
Maybe you harness to your PCM is lose or has a little corosion on it?? Seems like a PC related issue
Old 11-02-2011, 11:46 PM
mrmckeehan's Avatar
is there any where I can get a list of locations of all the grounds? I am going to check out the car tomorrow.
Old 11-05-2011, 04:10 PM
mrmckeehan's Avatar
a little update. now i can't even keep the car cranked. it dies when i go to give it gas. i went to drive it to my buddys shop where we did the engine install and it kept cutting off on us. so i parked it at a friends a mile away from my house and picked it up today and did the same thing. i am looking at it now back at my house.
Old 11-05-2011, 06:55 PM
Save the manuals!
wssix99's Avatar
So, it starts fine but dies whenever you press the gas? Can you ease in to it? Is the problem related to RPM only? (Can you accelerate slowly to higher speeds?)
Old 11-07-2011, 02:10 PM
mrmckeehan's Avatar
fixed....
the problem was the ground on the back of the head. it came loose and was not making good connection. tightened it down and it is now fixed and running good.
