crank postion sensor ???
Old 11-03-2011, 02:27 PM
SHibbY01WS6's Avatar
Default crank postion sensor ???
i searched all over and didnt find it so here we go. when i pulled the harness on the a 01 trans am with a 6-speed i pulled the 3 wires from the crank postion sensor and i was wondering if any has a diagram or could tell me were the wires go (ex. pink wire goes pin A, green goes pin B and black goes pin C) i know these arnt the real color but you gett the idea thanks
Old 11-03-2011, 04:51 PM
FiredUpZ28's Avatar
Dark blue/white is signal - A. Yellow/black is low reference (PCM ground) - B. And light green is power (12v reference from PCM) - C. Anything in particular your trying to figure out? Any codes?
Old 11-03-2011, 05:16 PM
JaYZeig's Avatar
A... dk blu/wht....... ckp signal inpput
B... yel/blk ...... reference low
C... lt green....... ign feed
Old 11-04-2011, 02:54 AM
perfect thank you
