Residue on and around the fuel injector
Old 11-04-2011, 02:41 PM
jaxcam02's Avatar
Default Residue on and around the fuel injector
I was under the hood today and noticed this white spot around the fuel injector. I have been hearing liquid evaporating under the hood after I turn the engine off but I could never pin point where it was coming from. Does this look bad and should I get the injector replaced? and if so am I correct in saying that I should change all the injectors out as well. 90k miles and well maintained.
Old 11-04-2011, 02:42 PM
jaxcam02's Avatar
at first glance I thought the spot was from a puddle from the chlorinated water that boiled off after a rinse down.
Old 11-10-2011, 11:22 AM
jaxcam02's Avatar
nobody? BUMP
Old 11-10-2011, 04:59 PM
blade2222's Avatar
Do you smell gas after running for a while?
Old 11-10-2011, 09:52 PM
jaxcam02's Avatar
a faint hit every once in a while at a stop. but its hard to tell with all the beaters on the road.
Old 11-11-2011, 05:55 AM
blade2222's Avatar
I'd check to see if water is leaking down on it first, if not could be a bad o-ring. No need to replace injectors just the o-ring.
Old 11-12-2011, 02:03 PM
jaxcam02's Avatar
thanks, gonna clean it up when i wash the car today and see if it happens again, hopefully its just the o ring like u said if anything.
Quick Reply: Residue on and around the fuel injector
