Power Steering HELP
Power Steering HELP
My power steering was a bit yellow and foamy when I got the car. I have flushed it a few times and it was gotten alot clearer( but still retaining a slight yellow color). I took off the stock PS cooler and bypassed it. It still feels heavy when turning. Does anyone have any idea what it could be?
I didn't have quite the problems you are describing, but I did have some slight squealing when turning the wheel. Someone on this board recommended putting in Redline synthetic power steering fluid. I removed as much as I could from the reservoir using a turkey baster, and filled with redline, ran the car and turned the steering wheel all the way back and forth, shut the car off, then repeated a couple times until the fluid was bright red. I have not had a problem with noise from the PS pump since.
I would think you could detach the return line on the pump but the system is pretty high pressure. Hopefully someone else here will chime in, because I have always done it the way I described and not had a problem.
I'd have to double check on which line is which, but you can use this procedure to flush the power steering:
POWER STEERING FLUSH
-remove PS cap
-remove return line and start engine. let drain
-pour PS fluid into reservoir at same rate it is draining
-at the same time, have a friend move wheels lock to lock several times
-once drainage looks like new fluid (probably 3 bottles wasted) stop engine
-let draining complete and re-attach return line.
-fill reservoir to proper level and run engine with cap off
-have a friend move wheels lock to lock several times to "burp" air out of PS system
-close cap
-DONE
Hope that helps.
-remove PS cap
-close cap
-DONE
Hope that helps.
It was was very foamy ( vanilla looking smoothie juice lol) but I tried sucking the fluid out a few times until it got rather yellow clearish. The car had the power steering cooling unit before and now I bypassed it. But the power steering pump may be going bad. Its rather harder to move the steering wheel than other camaros I've driven. Recently, a squeaking noise started. It sounds like a pulley or the belt. I dont know if that is somehow related to the ps pump issue.
Thanks for the info loyolacub68. I just need to see which is the return line and do what you said!
Save the manuals!
Save the manuals!
I sent mine to TurnOne to be rebuilt. In addition to racing/performance pumps, they will also do an OEM rebuild, if requested.
They did an OEM rebuild for me and so far so good. You'll pay a little extra money for the service, but you'll be sure its done right and you'll know better where the original parts have been previously.
