Ignition Key Dance Trivia:
Old 11-16-2011, 04:35 PM
Huntergreen's Avatar
Default Ignition Key Dance Trivia:
Hi all,
Without using an obd scanner, there is a way to check codes from your dashboard.....
Anybody have an idea on how this is accomplished using your ignition key.
Feedback(s) is greatly appreciated.
specs:
98 TA Conv.
Old 11-17-2011, 07:22 AM
Save the manuals!
wssix99's Avatar
No. That function died with the expansion of OBD-II. There are far too many codes available to flash back to you in code.
You can get a cheap scanner to give you the codes.
Quick Reply: Ignition Key Dance Trivia:
