View Poll Results: do you let your car idle for a few minutes before driving?
yes
34
70.83%
no
14
29.17%
Voters: 48. You may not vote on this poll
warm up car b driving?
I'm having a hard time finding some good info on this. I always thought it was a good idea to let your car idle for a few minutes before you drive off in the mornings. but someone told me that you don't have to do that anymore and it could be bad for the car. every morning i start my car about 5-10 minutes before leaving regardless of the temperature outside. i feel its good to get the oil moving and warmed up.what do you guys do? please post links that go into detail on this.
It depends. It is good to limit RPMs before oil is up to operating temperature. Before it warms and thins out you have pretty poor oil flow, since viscosity is high (which is why the pressure is way up when cold).
Excessive idling can potentially lead to fuel dilution of the oil, that is really one of the few downsides I can think of offhand. I don't know why someone would think it is bad to let it warm up before driving. I can understand why they might think it is unnecessary if the ambient temp isn't too low.
Save the manuals!
Its a total waste on a normal car. You'll warm it up faster by taking it for an easy drive and not revving the engine. If your car is still or moving, the same processes are happening inside the engine and oil flows the same. If anything, it will flow more and heat up faster by driving the car.
As long as you aren't in a climate that requires an engine block heater and are using the correct motor oil (this time of year, we should have at least 5W30 in) the car is fine to start and drive.
Here's a decent article: http://www.motherearthnews.com/ask-o...e-warm-up.aspx
There's no reason to let it idle for more than 20-30 seconds. After that just limit the rpms until the engine is fully warmed up and you should be ok. I say give it 30 seconds to just let the oil pressure build up and get to the top of the engine. Anymore than that is a waste of gas.
I prefer to let mine warm up for a few minutes before driving to the office because my commute is only 7 minutes, which isn't enough time to let the car get up to operating temp.
If you have a long, highway commute there is no reason to warm up your car. If you work close to home, you should warm up your car IMO.
Could say any better. I have done just that for eons and most of my cars make it past 250k miles with no issues.
As long as the oil pressure is up, time to put in gear, and usually the first mile or 2 is gentle, I don't dog my cars anyway, but WOT is always a daily occurance.... Just not typically until up to temp.
If your car has a carburetor, warm it up, if it doesn't don't bother.
Unless you are pulling right out of your parking spot and hitting a freeway on-ramp, then maybe a little. I have about 200 yards of idleing down the back road before I hit pavement, so I just get in and go.
Even a stock LS1 with the AIR pump shuts down the pump during the time it takes to close the garage and get back in.
A properly setup carb is just about as good as EFI in the extreme cold. My 307 Olds (later a 350, same carb/intake) would start absolutely fine, no pumping, even on -25F days. My 3800 in my 91 Bonneville started harder than my 85 Cutlass did. And I simply tapped pedal enough to set the chock (you hear it click) and no more, and crank it over and it started up immediately and drove just fine even in the cold.
But most people don't tune them either, I spent the time setting up the carb the way GM spec'd it.
I wait on the piston slap, squeaking clanging rattling and other horrible noises to stop before I move it. I also wait on the temp to get to about 100. Only takes a few minutes.
when i had my car i gave it about the time it took me to start up coast down my driveway then to the stop sign(i live on a hill) and then do a 1st 2nd gear pull wot reguardless if it was 30 or 80* and then would be on my way lol did it for like 2 years lol no problems
She starts, I hear the usual lifter noise for about 20 seconds; (from a cold start), I wait till it gets quiet (all ways under 30 seconds) and I drive off within 90 seconds.
Been that way for 11 years and I see no reason to change as the engine has superb oil pressure at all temps and rpms.
BTW, I always use 0/40 Royal Purple and a good filter that has a larger capacity than stock.
I've done what they said. I start my engine, summer or winter, I let it sit and idle just long enough to get my stereo on, belt on, and situate my things if I have any with me. I drive off in about 30-45 seconds usually. But I drive it very casually until its warm. I've been good for 9+ years.
