Barely Moving in Automatic:
Hi all,
Issue at hand:
Just recently took the my car out for a spin, then noticed that my drive stopped going into drive and the needle barely gets to the 10mph mark even with attempts to give it gas.....
Tried so far:
Took it to a transmission specialist, they said car is "very clean" and there is no issues with the transmission.
No engine light
Any ideas of causes and/or possible fix(s).
Thanks for the feedback.
Issue at hand:
Tried so far:
No engine light
its weird, when I took it to the specialist, the car was fine.
The next following day.. (today), the car acted up again.
I have no DTC codes, CEL codes......
I'm wandering... can a bad fuel filter have a role in this?
Just tried moving the vehicle.. and now it works normal... very weird....
car moves in 1 and 2 on initial starts.....
the last time my spark plugs were done.. was I believe in 2007......hmmm
** Follow up
Jam01 .... I was thinking the same thing..... but...
Finally found what was wrong with it..
The VSS (Vehicle Speed Sensor) needed to be replaced.
The original technician could'nt find anything wrong with the vehicle....
The vehicle was running fine.. then it acted up again..... needle dropping.. going into limp mode......
I took it back to the tech and they troubleshooted it again, this time did a thorough check on it.... long behold....... it was the VSS.
I wanted to share this in case others may experience this in the future
Thanks again for your replies, its truly appreciated.
