White smoke from exhaust
So I just got done replacing intake manifold gaskets, spark plugs, o2 sensors, oil, And fuel filter but When I started her up lastnight I had some white exhaust smoke should I be concerned? Any opinions would be appreciated. This was on a 96 lt1
how long did your car sit without being turned on? Same thing happened to mine. However mine was a bad head gasket, maybe yours is just condensation. Check your oil constantly to see if you have any coolant mixed in there. If not, take her for a short spin to see if it goes away.
finally was able to get it off the lift tonight and take her for a spin and the smoke went away but i will still check my oil often for a while just to make sure
