replacing radio antenni
Old 11-24-2011, 10:38 AM
robertbartsch's Avatar
Default replacing radio antenni
...snapped off in the car wash and a standard replacement will not work?
Is this a dealer item? UHG! It has a long arm that attaches to the braket that holds the spare tire...
Old 11-24-2011, 04:07 PM
sjsingle1's Avatar
you can get the whole assembly..........about 150$......or a mast repair kit........about 40$ on ebay
Old 11-26-2011, 03:01 PM
thanks
what is the mast repair kit like?
Old 11-26-2011, 05:01 PM
sjsingle1's Avatar
the mast repair kit includes the mast and the nylon guide ( its the thing that drives the mast up and down from the motor and it usually breaks ) .......so your motor must be working
Old 11-26-2011, 05:04 PM
sjsingle1's Avatar
this is the whole assembly
sjsingle1's Avatar
Old 11-26-2011, 05:36 PM
thanks.
Mine does not look like that.
Mine does not have a motor and the factory bracket goes from the spare tire brakcet to the top of the fender... the ONLY electric wire is the antenna wire to the radio and it is female not male
Old 11-26-2011, 08:11 PM
sjsingle1's Avatar
is yours electric?
Old 11-26-2011, 09:20 PM
LS1121's Avatar
Go to the junk yard and get one.
Old 11-26-2011, 09:21 PM
LS1121's Avatar
Originally Posted by sjsingle1
is yours electric?
I would say No! I thought he was talking about Electric also.
Old 11-26-2011, 09:55 PM
non electric ....
the "masts" on the web do not look like my stock unit
is this a dealer item?
Old 11-26-2011, 10:38 PM
sjsingle1's Avatar
if you want it to look stock you will have to get a GM replacement......to many variables in a aftermarket......and i believe you have the wiring already in place if you want to convert to electric
