Rotors grinding on brake pad retainer clips - videos
Old 12-21-2011, 11:24 AM
Not Brian's Avatar
Default Rotors grinding on brake pad retainer clips - videos
I installed new pads/rotors (Wagner Thermo-Quiet pads) awhile ago and the rotors were scraping hard on the new clip things. I just went yesterday and got everything swapped out for new stuff, free, and the rotors are still rubbing on them.
It doesn't do it with the caliper part flipped up and the main caliper body (whatever it's called) is bolted in place, but I show you here where it does rub once it's flipped back down.
http://www.youtube.com/watch?v=znl6s6q0ZEY
See when I lower that and put the wheel back on it sounds horrible
http://www.youtube.com/watch?v=1zD-_JknVhk
This shows the old clips from the first ones where the outer edges of the rotors are rubbing.
http://www.youtube.com/watch?v=MHghUP4X0a0
I can't seem to find any other hardware kits online to swap these out with, so my questions are where can I find a set that doesn't do this, or would it be okay to not even use them at all?
Old 12-21-2011, 01:48 PM
jam01's Avatar
bend it a little so it does not rub.
Old 12-21-2011, 01:49 PM
Not Brian's Avatar
They're bent as far down as possible to fit the shape of the caliper.. and if I cut that flap off there won't be much stopping them from shimmying left and right with the pads as the brakes are applied.
Old 12-21-2011, 07:57 PM
Not Brian's Avatar
I got drunk and beat the **** out of them with a hammer while they were on the caliper.. they conformed and man beat machine tonight ladies and gentlemen. Nice and quiet now.
Old 12-26-2011, 01:31 AM
sjsingle1's Avatar
WTF? i put new clips in mine and did not have any problems like that............sure you put them in right?
Old 12-26-2011, 06:18 AM
senicalj4579's Avatar
Doesnt matter if they are put in right. Just as long as you get drunk and beat them to hell with your hammer it will be good to go. Isnt that right OP?!
Old 12-27-2011, 06:47 PM
rabbit320's Avatar
i ground mine with a dremel, when i replaced a caliper, rotor, and pad all from advance. dunno wtf was going on, if they changed clips or if design had changed or...?
Quick Reply: Rotors grinding on brake pad retainer clips - videos
