vats mod question
vats mod question
Is it possible for a vats bypass mod to go bad? The bypass was bought off ebay i believe, and the red led on it is on, because car is cranking, also checked at the rear harness and there was no power. could the electrical ignition switch on top of the column at the bottom possibly go bad, because the car cranks in gear regardless if the clutch pedal is pressed down or not. By the way it Is a 97 m6
