Common pulley issues with the ls1?**UPDATE ENTER**
Old 01-10-2012, 02:40 PM
jbridwelltransam's Avatar
Default Common pulley issues with the ls1?**UPDATE ENTER**
I got a manual belt tensioner, but it seems like there is some pulley or pulleys that are attempting to toss the belt. The power steering pulley has some side to side play in it and there is an occasional noise coming from the belt when running. any way to tighten up the PS pulley?
Thank you
Old 01-10-2012, 10:04 PM
bump no one has had any more issues?
Old 01-11-2012, 04:26 AM
FX MASTER TK's Avatar
Angry
one of mine is making a rattly shaking sound... is the bearing had it?
Old 01-11-2012, 05:13 AM
ls1ya's Avatar
Bearings going out. Mine is to. Should have changed them both at the same time.
Old 01-11-2012, 05:59 AM
xenergyx's Avatar
one of my pulleys is squeaking every time it rotates does it just need to be greased? or is the bearing going out in one of them i wanna say its the tentioner for the serpentine belt
Old 01-11-2012, 06:57 AM
ls1ya's Avatar
Yeah the bearing is going out. That pulley is only like $10-15 a kragen. Just waiting on my tranny mount to come in so I can do them both at the same time
Old 01-11-2012, 08:51 AM
Save the manuals!
wssix99's Avatar
Thank you
You would need a PS Pulley puller to do this. Part of the tool/kit pulls the pulley off and the other part presses it on. The pulley itself is plastic and could be cracked, etc.
Old 01-11-2012, 10:40 AM
could i rent one of those from advance auto? I'll look into it this weekend, take my belt off and test the pulleys. Can someone post a pic of their idler pulley? The one above the balancer. Also would it throw anything off since I don't have the AC belt on?
Old 01-13-2012, 08:35 PM
Update** Checked the pulleys and it seems like the water pump pulley is wobbly and I was wondering if anyone else had this problem and it causing the belt to walk off??
Old 01-17-2012, 07:22 PM
no one else have anything to say?
Old 01-17-2012, 11:01 PM
14k
14k's Avatar
if its wobbling just replace the pump
Old 01-18-2012, 05:22 PM
xny1989's Avatar
The water pump pulley shouldn't be wobbly - how's your coolant level?
Old 01-18-2012, 08:51 PM
Got a replacement pump gonna put it on this weekend. No coolant leaks or anything. And it's a 98 so it is a bolt on pulley, but it was tight and the shaft was wobbly. Will my same thermostat work? The new pump has the pressed on pulley and it looks about the same.
Old 01-20-2012, 09:00 PM
Put on a new waterpump and it seems like that may have fixed it.
Old 01-21-2012, 09:23 AM
xny1989's Avatar
It's nice to get a problem like that resolved so easily!
Old 01-21-2012, 12:25 PM
We'll see after I put some miles on it, looks like the balancer may be wobbling a tiny tiny bit, but I drove it pretty hard last night and it ran just fine.
Old 01-24-2012, 08:42 PM
billscamaros's Avatar
just found this thread .... i've been chasing a gremlin in my pulley system also. i replaced the PS pump and water pump, the main belt tensioner and the idler pulley. i still have a slight squeal coming from the PS pump ..... i'm starting to think that my "new, remanufactured" Autozone PS pump isn't quite up to par. (hence my post on where to buy parts).
like jbridwell's last post ... i noticed the other day that the harmonic balancer also has a slight wobble to it. does anyone else have this problem? i've never pulled this one off, and the car has a ton of miles on it since i bought it .. so it hasn't been a big problem yet. just curious if any of you have this problem also?
Quick Reply: Common pulley issues with the ls1?**UPDATE ENTER**
