Changing O2 sensor...
Old 01-23-2012, 11:43 AM
bigbomber5's Avatar
Default Changing O2 sensor...
My car has a very strong gas smell when it is started. Its a 2002 TA with 113,000 miles. I've done some research and the most common cause is a bad/failing O2 sensor/s. Is this something I can attempt to fix on my own or should I take it to a shop and have them take a look?
Thanks!
Old 01-23-2012, 04:26 PM
puddingmmmmmmmm's Avatar
If you can change your own oil, you'll be able to change the o2 sensors. To make it easier I would buy a socket specifically for o2 sensors.
Old 01-23-2012, 06:46 PM
V68Sweep's Avatar
You can definitely do this on your own. You will need a jack/jack stands. I changed out mine. The sensor on...I think the driver side was pretty annoying to get to, but nothing too crazy.
Old 01-23-2012, 08:28 PM
bigbomber5's Avatar
Thanks for the info guys.
Old 01-23-2012, 09:19 PM
94'BLKBRD's Avatar
Spray the sensors with some Liquid Wrench a day or two before you remove them.
Old 01-24-2012, 08:25 PM
billscamaros's Avatar
I changed both sensors in front of the cats the other day. With over 200K miles on this car, I expected these sensors to be rusted in place. But amazingly enough, both sensors came loose easily and I changed both in 10 mins. Definitely not a hard task.
Quick Reply: Changing O2 sensor...
