stupid idle, help?
stupid idle, help?
Well i got my trans am running and its runs awesome! this time around though i put on a new typhoon 96 mm intake and throttle body and i had the computer mail order tuned. The car runs awesome but when at a stop it takes like 30 seconds to get to normal idle, and when im moving it wont go below 2400 rpm, i can actually drive the car without touchin the gas pedal because it stays at 2400 rpm. I know a vacuum leak may be the cause...what do you guys think?
I know the throttle position sensor is correct, and i know the seal on the throttle body is good.... and i know what you all think about the typhoon but its a christmas present and aside from this, i am happy with it.....
Any help would be greatly appreiciated, thanks
Man im having the same problem...Well not as high of RPM's.. but same way..my Tuner would tune and within a few days it goes back to the high rpm thing..I hope someone can give some info...
