Fuel pump relay - LS1TECH
Fuel pump relay
Thread Tools Search this Thread
Old 04-10-2012, 09:13 PM   #1
Default Fuel pump relay
Where is the fuel pump relay on a 93 t/a? Thanks for the help!
97ta383 is offline   Reply With Quote
Old 04-10-2012, 10:19 PM   #2
Should be in the Fuse/Relay box under the hood on the driver side. Should be between the strut tower and headlight.
DisasterFormula is offline   Reply With Quote
Tags
1995, 93, 95, fuel, ls1tech, ls4, pump, relay, trans, where
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
