headlight motor grinding after closed
i have a 2000 pontiac firehawk. recently when i turn my headlights off, the drive side headlight motor makes a buzzing noise after the headlight is closed. also when i lock my car with my key fob the headlights open and then shut. what could cause these issues and how can i fix them.
Its been a while. I had the motor out twice. Once to swap the gear out then again to swap the motor. 2nd time about 20 minutes tops.
