Fuel Pressure Help - LS1TECH
Fuel Pressure Help
Thread Tools Search this Thread
Old 05-03-2012, 07:58 PM   #1
00ws6indubv's Avatar
Default Fuel Pressure Help
My car bucks/ hesitates at cruising speed when under a load. Tested fuel pressure. It reads 55-60 when you turn key on it starts fairly easy. when you hit accelerator hit wuickly drops then builds back up. Also when you shut off car the pressure instantly drops to 0 . From my understanding it is NOT suppose to drop instantly. What does this sound like injector. fuel pressure regulator, pump going bad?
00ws6indubv is offline   Reply With Quote
Tags
2000, drops, fuel, instantly, load, neon, pressure
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
