Car just died, what happened?????? - LS1TECH
Thread Tools Search this Thread
Old 05-06-2012, 02:06 PM   #1
Default Car just died, what happened??????
I was driving to work, car was running fine, and I turned down the street got on the gas, car just sputtered and died, tried to crank it back on and it would fire up and die again. Only light that came on was the check gauges light (it does have gas).
car was running strong, it's got 91K miles but this was very sudden, just died.
As it was struggling to stay on and died I did hear an air/wooshing sound coming from the passenger side header area.
any ideas?
thanks
z28pat is offline   Reply With Quote
Old 05-07-2012, 09:31 AM   #2
Check fuel pressure.
blade2222 is offline   Reply With Quote
Old 05-07-2012, 06:21 PM   #3
Ruthless909's Avatar
^^^ yeah that
Are you on the original fuel pump?
Ruthless909 is offline   Reply With Quote
Old 05-08-2012, 12:37 PM   #4
turns out it was throwing a maf code, so I started it with it unplugged vs plugged in and it ran fine so I'm looking into an slp or other maf
thanks
Old 05-08-2012, 01:15 PM   #5
Jr.Samples's Avatar
Quote:
thanks
Did you try plugging it back in? Maybe it had dirty connectors??
Jr.Samples is offline   Reply With Quote
Old 05-08-2012, 05:28 PM   #6
thanks
You don't need a MAF. I drove for two years with mine unplugged. Same gas mileage, same power, same everything. If anything.......it will idle a little rough at cold start for like 30 seconds.
LS6427 is offline   Reply With Quote
Old 05-09-2012, 10:29 AM   #7
no ****, I didn't know that.
didn't want to run it w/o one so I ordered a granatelli one from a member here
Tags
be, blaze, car, check, die, died, dies, driving, gauges, happened, light, running, street, vould
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
