What causes a fuel gauge to go bad?
Old 05-10-2012, 06:54 PM
01BlueSS1995's Avatar
Default What causes a fuel gauge to go bad?
As the title states, im wondering what causes a fuel gauge to go bad, as mine has seeming went out. It works from full to a 1/4 then it seems to stick, and will eventually drop to a half, from time to time the guage will flicker to where i believe it needs to be but does not stay there. Sometimes you can glance down and you will see the needle bouncing but it always ends up where i know it doesnt belong. Any input is appreciated!
Thanks,
Austin.
Old 05-10-2012, 07:29 PM
flintwrench69's Avatar
The small metal contacts on the fuel level sensor wear out. This creates a bad connection & causes the fuel gauge to read erratic, or stuck on E or F.
Old 05-10-2012, 07:35 PM
is this an easy fix or a PITA?
Old 05-10-2012, 07:50 PM
You could drop the tank & change it but thats the hard way IMO. You can cut a trap door above the tank like this:https://ls1tech.com/forums/fueling-i...where-cut.html
If you have a plastic tank use the 2nd pic.
Old 05-10-2012, 09:40 PM
Grimes's Avatar
sometimes it is buildup on the sensor. run some techron cleaner or redline fuel cleaner for your next couple fills
Old 05-11-2012, 07:42 AM
NC01TA's Avatar
Interesting. Wonder if ethanol affects this too like everything else?
Old 05-12-2012, 01:36 AM
Thats a rare case that its that. Fuel level sensors going out is very common on a GM vehicle.
Old 05-12-2012, 05:53 PM
sjsingle1's Avatar
its the SLOP in the bushing where the arm and contacts are ...........there is a u tube video demonstrating this......and i found it 1st hand when i changed my pump
Old 05-13-2012, 05:21 PM
VandykeT/A's Avatar
Mine worked perfect down to 3/4 of a tank and then it went all to hell. It would just be sitting there working and then drop to empty and show check gauges. It was the sensor. Its got 5 or 6 little fingers that sweep across and make contact as the float goes up and down. Mine had about 2 half fingers. I changed the sensor and it works perfectly. I even had a code fuel level sensor high voltage.
Old 05-13-2012, 05:34 PM
mikh338's Avatar
bingo!! my car does the same thing and has the same problems. getting ready to fix it as i ran out of gas last night on the way to meet up with a bunch of people lol, had to call for a gas can HAHA. here is the link for what you need. http://www.racetronix.biz/itemdesc.a...%2DF99&eq=&Tp=
Quick Reply: What causes a fuel gauge to go bad?
