Removing the center console issue - LS1TECH
Thread Tools Search this Thread
Old 05-23-2012, 02:56 PM   #1
Default Removing the center console issue
Im trying to get to my reverse switch in my 98 Camaro A4. Im trying to lift the center console now, I got the 2 bolts in the front, the 2 in the box, and Im trying to lift it from the rear seat. Seems like something is still holding it in place. Did I miss something?
PNW Z28 is offline   Reply With Quote
Old 05-23-2012, 11:20 PM   #2
I copied this from another post in a different thread. I plan to tackle this this weekend.
1) Remove two bolts where the console meets the dash.
2) Remove the shift ****.
Set Parking Brake, pull lever back to 1 or 2. Pull retainer out with a small pick or screwdriver from the front of the ****. Pull up/off ****.
3) Remove the coin holder by pulling straight up. Remove two screws that were hidden under there.
Pull upper section of the console off.
That should be everything.
Stu_x24x is offline   Reply With Quote
Old 05-24-2012, 01:46 PM   #3
ghardester's Avatar
Yeah, you probably just missed the 2 screws hidden under the cup holder. Also, to remove the shift handle there is a little U shaped retainer to pull out.
Not sure about the Camaro but it is probably similar to the Firebird. On the Firebird the U retainer is on the front of the handle, you can't really see it until you turn the key on and shift into 1st. It just prys out using a small screwdriver or needle-nosed pliers.
ghardester is offline   Reply With Quote
Tags
98, a4, arctic, camaro, cat, center, console, cup, holder, lights, ls1tech, put, remove, removing, ta
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
