Power steering return hose????
1 Post
So from what I've read, there are no places to buy a new return line for my '98 Z28. I searched a little bit and from a few threads I've read of people doing different things. Do you guys have any sure fire ways of replacing the return line other than buying used? Please post up specifics on how you did it. Thanks for any help in advance.
Its nice to see you are local. Here is a thread you should check out.
https://ls1tech.com/forums/general-m...oler-hose.html
Does your car have the factory cooler? I ordered hose number 14 from the diagram from https://www.1stpontiacparts.com/partscat.html, and have ordered from them many times. They are out of Wasington and have lower shipping than gmpartsdirect.
Exactly......I dremeled an old crimp off, exposed the inner metal hose and clamped the factory hose back on it with two clamps. Its an A/C line. Its been there for like 3 years......PICS BELOW.
People said it wouldn't hold for a week. WRONG.....
There's a shop in town here that will take any of our GM hard lines, dremel the old crimp off and re-crimp with new crimp clamps and the appropriate type hose (a/c lines high or low pressure, coolant lines, power steering lines, etc,...) and they will be good as factory new.
Since my engine is out, I'm bringing my factory metal/rubber heater core to water pump hoses to them....$25.00, they give them back with new rubber and crimpes....good as factory new.
Also doing it to the a/c line in the pics below, that line attaches to the back of the compressor and the bottom of the condensor.
You must have a shop like that around you too.....
1 Post
Thanks for the responses guys, I got a great used set of hoses from a tech member yesterday. If anything goes wrong I know exactly what to do now. Also, if anyone has the same question they can search and get the answer in this thread.
Sorry to bring this thread back from the dead... sorry if that's the wrong thing to do...
Instead of using a dremel to remove the crimp, why couldn't I just cut the rubber hose about 1" to 2" from the crimp and use a brass barb and band clamps to run a new line to an aftermarket cooler? Would I be asking for leaks by doing this?
from what i can remember the return (low pressure) hose first starts at the steering gear and then goes to the cooler if you have one, then back to the reservoir.
where that hard return line at the gear turns into a rubber line, if that crimp is not leaking then no i don't think you will have any problems doing what you want to do.
if & when that crimp does start leaking then your fall back is dremeling the hard line prior to the crimp and then attaching a rubber hose with clamp onto that.
i'm surprised rockauto does not have that return line.
I'm not 100% sure but I'm starting to see this part number pop up on the popular GM parts online sites again without the note about it being discontinued. Definitely visit your local Chevy parts counter or call before ordering to be sure.
26068527 I think is the line from the rack to the stock cooler on the LS1. There is a different part for cars without the stock cooler which does seem to be discontinued still.
I'm replacing the stock cooler and need a longer section of hose. I'm just going to add a bit of length with a barbed brass fitting and band clamps. It shouldn't leak but I'll keep an eye on it.
Fab
