Overheating .......... - LS1TECH
Thread Tools Search this Thread
Old 06-26-2012, 11:36 AM   #1
Skvr_Z's Avatar
Default Overheating ..........
Ok I recently installed new cooling fans, new 160 degree thermostat ,but a week ago I noticed my temp gauge would stay slightly under 210 for about 25-30 mins then the temp would slowly rise , I checked for any air bleed the line under the tb, an still have overheating issues I noticed only one fans would be on an sometimes the second would kick on after I turn the car off , does anybody have any advise or tips , thx
Skvr_Z is offline   Reply With Quote
Old 06-26-2012, 12:10 PM   #2
Usually fans are set to kick on at like 226 or something for fuel economy. Retard timing and what not. I suggest getting a tune for them to kick on at a lower temperature or wire in a manual fan switch.
DisasterFormula is offline   Reply With Quote
Old 06-26-2012, 01:52 PM   #3
Fans MUST come "on" and go "off" together.......always. They also always work in LOW and HIGH at the same time.
You have a fan issue.
Your temps should decrease and run below 210 if cruising on the highway.......if its still getting hotter than 210 and increasing while cruising....you have another issue.
LS6427 is offline   Reply With Quote
Old 06-26-2012, 02:03 PM   #4
Skvr_Z's Avatar
I know that one fan comes on yesterday I drove the car for about 20-25 mins, and stop at a target 6-7 miles from me and one fan was blowing on high
Old 06-26-2012, 02:15 PM   #5
Skvr_Z's Avatar
Also , when cruising on the highway temp would drop back then when stop n go it would go back up
Old 06-26-2012, 05:33 PM   #6
Quote:
Your problem than....is your fans. You have to find out why they are BOTH not running TOGETHER.
I'm not positive.....but I think a failing "coolant temp sensor" can cause the fans to wig out. Not sure which year PCM you have....I see you have a crate engine. Some years act differently when temp sensors start to act up.
Old 06-26-2012, 07:10 PM   #7
Skvr_Z's Avatar
My car is a 99 with the stock PCM
Old 06-29-2012, 02:52 PM   #8
Skvr_Z's Avatar
I installed a new rely ,new coolant temp sensor ,bleed the coolant and the car still overheats don't have a clue whats going on
Old 07-01-2012, 12:38 AM   #9
Read post #3 again.
Old 07-08-2012, 10:52 AM   #10
Skvr_Z's Avatar
Anybody in the NYC area interested in taking a look at my car
Old 07-15-2012, 09:07 PM   #11
95badboy's Avatar
Bump for this thread I have a 99 ss doin the exact same but it pushes watercoolant out the over flow
95badboy is offline   Reply With Quote
Old 07-15-2012, 10:45 PM   #12
how does it act when you turn on the A/C. Running the a/c will cause both fans to operate.
LS1121 is offline   Reply With Quote
Old 07-16-2012, 07:29 AM   #13
95badboy's Avatar
Aint tryin to steal the thread but mine don't help any
Old 07-24-2012, 05:13 PM   #14
Skvr_Z's Avatar
Still having overheating issues , new water pump thermostat ,hoses , out the funny thing is I would pull over to check if my cooling fans is on an only one "driver side" is blowing on high , the only time they both on is if my car get too hot & I shut her down then they both stay on
Old 08-03-2012, 02:24 PM   #15
Im having the same problems
azvette89 is offline   Reply With Quote
Old 08-03-2012, 05:05 PM   #16
I know this might sound stupid but look up inside where the radiator is because I had picked up one of those plastic shopping bags like you get at the supermarket, somewhere on the road and it was blocking the air flow.
Old 08-06-2012, 12:52 PM   #17
Skvr_Z's Avatar
I took my car to a radiator shop that checked out ok , I'm not leaking, smoking, losing coolant nothing, got the motor checked out , that's fine idk
Old 08-07-2012, 12:22 AM   #18
88blackiroc's Avatar
What would the other issue be? My car has this problem where the the heat will increase on the highway while cruising and it climbs higher when i go wot. However, ive seen it rise while not being on the gas and cruising. Ive bled the system, its a new tstat, what could it be? Car is a 88 camaro with a 99 pcm and wiring harness
88blackiroc is offline   Reply With Quote
Old 08-07-2012, 01:35 PM   #19
I'm thinking it's gona be a fan problem, my car is running past 220 and when I open the hood only one fan is on. Weird because when I turn the AC off the driver side fan turns off and the passenger side then turns on. Anybody know the reason for that?
Old 08-07-2012, 04:02 PM   #20
1_MEANZ28's Avatar
Quote:
replace the radiator's cap,,trust me ...been their done that
1_MEANZ28 is offline   Reply With Quote
Tags
210, 30, drop, griffin, guage, heating, ls1tech, mins, overheating, rising, slowly, temp, temperture, thermostat, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
