Another Chirping pulley question?
When the car is cold, running at idle, you can hear the chirping noise. It does get louder as you rev the car.
After the car warms up, the noise goes away at idle but you can still hear the noise as you drive the car & rpm is up.
Noise goes away when I remove the belt. Verified this twice.
New belt installed.
AC removed
All pulley's spin freely with no noise with the belt removed EXCEPT the power sterring pulley. When I spin the PS pulley it doesnt free spin like the others but I can still spin it by hand. You can tell that there is a little tension with trying to spin it. When I spin the PS pulley I hear almost like a clicking sound. While im driving the car, the power steering seems perfect.
Any idea's?
thanks
New belt installed.
AC removed
Any idea's?
thanks
LS1Tech Administrator
Received 1,492 Likes
It's more likely the idler or tensioner/tensioner pulley for the respective belt system that's making the noise (either A/C or main), your post was unclear as to which belt was removed to stop the noise.
The most likely culprits are tensioner and idler pullies. FWIW, I had a chirp on the main belt system that acted like yours, and even though my alternator pulley would make a bit of noise when spinning it by hand, this was NOT the pulley responsible for the squeak/chirp with the engine running..... it ended up being the [main] tensioner.
just a update, I had the car jacked up with it running. I tried pin pointing where the chirping noise was coming from. I think I narrowed it down to either the idler pulley or the altanator. So I removed the idler pulley & after reading about regreasing the pulley before buying a new one, I decided to try that. So after regreasing the original idler pulley, I started the car up and the noise was gone. Im hoping that fixed it. It was very simple.
