Throttle Cable clip lost :( - LS1TECH
Thread Tools Search this Thread
Old 07-05-2012, 05:37 PM   #1
Default Throttle Cable clip lost :(
UPDATE: Posted Pic
Does anyone know the part number or where I can get the clip to adjust the throttle cable ? When trying to adjust I popped it off and it flew and lost it
thanks
needtransam is offline   Reply With Quote
Old 07-05-2012, 05:56 PM   #2
updated
Old 07-06-2012, 11:47 AM   #3
anyone???
Old 07-14-2012, 05:50 PM   #4
Z28SLPCAMAROZ28's Avatar
Did you check the part numbers sticky?
Z28SLPCAMAROZ28 is offline   Reply With Quote
Old 07-14-2012, 06:01 PM   #5
Here is a link to the 93-02 Camaro Parts Manual in pdf form. Download it and you should be able to find the part #.
Edit The link didn't work so do a google search for 93-02 Camaro Parts Manual.pdf
Todd
2002ss335 is offline   Reply With Quote
Old 07-15-2012, 10:38 AM   #6
Ghostintheshell's Avatar
I'll share MY experiences....
Without that clip, your throttle won't work as it should. It may remain open slightly - and the cable will shift and change.
So, I searched for a 98 throttle cable with traction control... For a long, long time. I think it took me a year to find. Depending on the year of your car, and if your car came equipped with traction control or not, will determine what cable you need.
It's severely annoying trying to track down these pieces.
Check ebay - as they come up - but the throttle cables clearly are a problem - and I refused to buy used.
Ghostintheshell is offline   Reply With Quote
Old 07-24-2012, 02:52 AM   #7
xxrillixx's Avatar
Did you get this fixed? I probably have one. PM me, ill send it to ya.
xxrillixx is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Cruise and traction control delete. ?? Lost sabersaw30 Generation III External Engine 10 04-12-2014 01:44 PM
WTB: Throttle or cruise cable end & fuel rail damper C clip. tylert14 Parts Wanted 8 02-24-2014 07:44 PM
Throttle cable clips? jersyboyy New LS1 Owners - Newbie Tech 1 08-20-2013 12:12 PM
Throttle body cable? need help detroit_903 LT1-LT4 Modifications 2 05-08-2013 12:17 PM
Tags
1998, 2000, 2001, 9302, adjust, cable, camaro, clip, download, ls1, manual, problems, repair, tech, throttle, yellow, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
