what hose is this, and would it cause my a/c to run like crap? - LS1TECH
Thread Tools Search this Thread
Old 07-12-2012, 11:33 AM   #1
jdoostil's Avatar
Default what hose is this, and would it cause my a/c to run like crap?
its idling not so well either. the car is in the shop now, so any help is appreciated!
99 TA LS1
what hose is this, and would it cause my a/c to run like crap?-img_20120712_122136.jpg
jdoostil is offline   Reply With Quote
Old 07-12-2012, 11:49 AM   #2
Undertow74's Avatar
That is your PCV Valve hose, and with that being kinked like that, yes it will make your car idle like crap. Either rip the whole PCV system out and replace it with a LS6 valley cover, or just get a new hose for the PCV
Undertow74 is offline   Reply With Quote
Old 07-12-2012, 11:56 AM   #3
pull that kinked hose off and replace it with a small piece of fuel line 3/8". I would also check out the rest of the PCV lines for rot. Probably find another hose set up ebay pretty cheap. LS6 valley cover is not necessary.....Period! Unless you just feel like spending money.
LS1121 is offline   Reply With Quote
Old 07-12-2012, 12:47 PM   #4
jdoostil's Avatar
Does that hose seperate, or is it just one long hose?
Old 07-12-2012, 12:47 PM   #5
jdoostil's Avatar
I'm thinking it seperates at the pvc valve?
Old 07-12-2012, 02:18 PM   #6
jdoostil's Avatar
fixed! thanks!
Old 07-12-2012, 02:44 PM   #7
sjsingle1's Avatar
if that happened to your little hose........think about the back of the hose behind the intake where you cant see it.........been there DONE that......LS6 valley cover FTW!!!!!
sjsingle1 is offline   Reply With Quote
Tags
ac, cars, cover, crap, hose, ripped, run
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
