Someone hit my car, cant figure out what is wrong. - LS1TECH
Thread Tools Search this Thread
Old 07-22-2012, 01:22 PM   #1
Default Someone hit my car, cant figure out what is wrong.
I was hit on the passenger side right around the wheel the other night coming home. I was able to drive the car home but it was pulling pretty hard. When I looked at it there was some real negative camber on the passenger side. I took the wheel off and structurally speaking, I can't find anything that sticks out at me. Doesn't look like anything is bent or buckled anywhere. The steering knuckle is basically resting on the shock and the tire was rubbing against one of the castle nuts towards the upper control arm.
Talking to my friend he said he would replace the steering knuckle, upper control arm and the wheel bearing to be safe. I also need to replace my tie rod ends because they were already bad. I'll try to upload a picture in a couple minutes but I was wondering if you guys thought I should go ahead and order those parts or if you think its possible that this guy just knocked my alignment out of whack.
Thanks in advance
edit* heres pictures
outside showing the negative camber. And generally where I was hit
the knuckle on the shock. and you can see the pieces of tire that were rubbed off on the castle nut
just another general picture I took
Its hard to get good pictures from inside the wheel well but hopefully those show something..
nodnarb481 is offline   Reply With Quote
Tags
agaist, bolt, camaro, cambered, car, figure, hit, ls1, passenger, rear, rubbing, side, tire, wheel, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
