Headlight motor problem again - LS1TECH
Thread Tools Search this Thread
Old 07-22-2012, 08:58 PM   #1
rxrom's Avatar
Default Headlight motor problem again
When I turn on the lights on my 2000 trans am the driversid light goes up the just falls back down. I'm trying to figure out why this is happening. I noticed that there is a plastic stop missing that stops the arm that's connected to the motor. Or is it something else.
Thanks
Roman
rxrom is offline   Reply With Quote
Old 07-23-2012, 06:17 AM   #2
Save the manuals!
wssix99's Avatar
Is the actuating arm hitting the metal stop that the plastic went on? How long has it been since you last worked on the motor?
wssix99 is online now   Reply With Quote
Old 07-23-2012, 12:13 PM   #3
rxrom's Avatar
This is a different trans am. I never did anything to this motor (have only owned it for 2 years). The arm misses the metal tab. It seems loose. I tightened all the bolts but still loose.
Old 07-23-2012, 12:30 PM   #4
Save the manuals!
wssix99's Avatar
The arm is keyed to the square edges of the motor shaft. You'll have to wiggle it a bit before it will slide down on the shaft securely. Sometimes, just tightening the bolt won't be enough to get it pressed on the shaft if its not lined up correctly.
Once its on the shaft and pressed down, it should be fine.
You might also check the angle of the stop tab and make sure it matches the other side of the car. I had the same thing happen to me and once the arm started going by the tab, it had leverage on the very end and bent it a little.
Here's a good tip for replacing the plastic bumpers that you are missing: Looking for Firebird headlight door actuator bumpers
Old 07-23-2012, 03:42 PM   #5
rxrom's Avatar
Thank you very much. I'll be making a new stopper and checking alignment over the weekend.
Old 08-01-2012, 08:25 AM   #6
rxrom's Avatar
Back yard mechanic way I fixed the arm from missing the metal stop tab. Took an three prong to two prong cord converter (for electrical cords that have the ground but the house autlet that has no hole for ground). Ripped out the metal prongs. Slight trim with utility knife. The larger hole is perfect snug fit. Costs 0.50 cents.
Old 05-25-2016, 12:29 PM   #7
Viper's Avatar
Sorry to bring this up from the dead but I'm missing the stop on my 97TA. I think and have to go verify tonight, that the stop is molded plastic on the 93-97 headlights. Anyone confirm?
Viper is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
missing headlight bump stops cause case to crack tarheels15 General Maintenance & Repairs 6 09-01-2015 07:06 AM
4L80e lugging second on decel Shownomercy Automatic Transmission 5 06-27-2014 03:56 PM
increase rod bearing clearances for 200 HP shot? 3rdCoastPowerSports Generation III Internal Engine 13 04-09-2012 12:39 PM
headlight grinding 20ls100 Corvette Performance 8 08-22-2006 07:27 AM
Who wants to trade??? yekta Western Members 7 01-03-2005 01:32 AM
Tags
1999, 2000, actuator, arm, car, firebird, headlamp, headlight, ls1tech, motor, plastic, pontiac, problems, stops, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
