air conditioner - LS1TECH
air conditioner
Thread Tools Search this Thread
Old 08-02-2012, 09:12 AM   #1
kernandl's Avatar
Default air conditioner
while driving home yesterday I noticed that my A/C wasn't blowing very hard. the air coming from the vents is cold. I checked the A/C comp. belt and all appeared to be ok. But even when the controls were set to "max" and on Highest setting it felt that there wasn't very much "wind force" (can't figure out an easier way to describe,sry.) emmitting from the vents. it felt like my A/C was on "low". anybody got ant ideas on the problem I'm having and how to fix? P.S. - ambient outside temp with heat index has been 112 degrees..
kernandl is offline   Reply With Quote
Old 08-02-2012, 10:06 AM   #2
Decadence75's Avatar
Quote:
I would check the blower motor.
Decadence75 is offline   Reply With Quote
Old 08-02-2012, 10:32 AM   #3
kernandl's Avatar
is there a way to test to see if it's working properly or is it either "working or not"?
Old 08-02-2012, 10:36 AM   #4
I would check the fuse first of all to make sure it wasn't blown.
Old 08-02-2012, 10:41 AM   #5
kernandl's Avatar
thanks! will do.
Old 08-02-2012, 02:24 PM   #6
DAVE00's Avatar
As stated check the blower motor and pull it down to make sure there is not debris in there as it's very common on the fbodies for leaves and crap to get in there an clog up the blower fan. Also, you could also be low on freon and the evap coil freezing up not allowing much air flow.
DAVE00 is offline   Reply With Quote
Old 08-03-2012, 11:46 AM   #7
kernandl's Avatar
thanks, I'll add that to the "honey-do-list" this weekend.
Tags
00, 2002, ac, air, ant, blown, condition, conditioner, fast, freezes, houston, powered, problem, trans, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
