Yup its a low coolant question.. - LS1TECH
Thread Tools Search this Thread
Old 08-07-2012, 12:46 AM   #1
Exclamation Yup its a low coolant question..
So my car will randomly pop up low coolant. the radiator is full to the top. I took the sensor off and cleaned it all out but the problem still occurs. Now the thing is, when the light comes on. my engine temperature gets up to the 210 mark and even a little farther. it has NEVER gotten up to 210 before and i doubt its ironic right when the light comes on its "reading hotter" Could this be only the coolant sensor? or could there be a water pump issue of some kind.. I"m confused
tylerdietzenbach is offline   Reply With Quote
Old 08-07-2012, 12:49 AM   #2
my bandit's Avatar
if the coolant is still full, it could be that the thermostat is stuck and not turning on the fans. the coolant sensor only shows the level, you can take that off and clean it, its on the passenger side near the top of the radiator. i had a coolant leak that i couldnt find for a while until it got bad, turns out it was coming out from underneath the WP pulley
my bandit is offline   Reply With Quote
Old 08-07-2012, 12:54 AM   #3
blk/slvr02ss's Avatar
Yes it could be the T-Stat or air bubbles in the system that need to be bleed out.
blk/slvr02ss is offline   Reply With Quote
Old 08-07-2012, 01:01 AM   #4
I guess i wasnt thinking of thermostat.. and I have already cleaned the sensor. it doesnt leak anywhere. I've had the car for a year and its been at the same level since i bought it. Is it possible the thermostat gets stuck randomly? in the past on other cars I have owned, once they're stuck, they're stuck. One more thing, the overflow tank dipstick was moderately gummy.
Old 08-07-2012, 07:28 AM   #5
Save the manuals!
wssix99's Avatar
Quote:
This isn't uncommon - especially in hot weather with the A/C on. You probably just didn't notice it before because your attention wasn't on the gauge.
Bottom line - if the sensor is coming on and fluid is over the sensor, the sensor is most likely shot. You'll see folks recommending just to unplug the sensor, but IMO - its really important. It saved me from a melt-down when I had a bad water pump. (The pump was putting so much air in to the system, that the radiator became half-full of air.)
Maybe, the pump is bad also - but the most likely cause is just the sensor.
wssix99 is offline   Reply With Quote
Tags
coolant, dip, full, light, low, ls1tech, pop, showing, sign, stick, trans, truck, yup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
