2001 Formula LS1 head cover removal - LS1TECH
Thread Tools Search this Thread
Old 08-09-2012, 05:40 PM   #1
Default 2001 Formula LS1 head cover removal
Anyone have any tips on getting that 15mm bolt on the back side of the head that holds the bracket for the AIR system manifold? I want to get the cover off and look for a stuck valve. Also, looking for an LS1 rebuilder in central NJ. I'm pretty sure mine has a spun bearing based on the amount of metal I found in the oil pan. Didn't see much in the filter.
Fireman23122 is offline   Reply With Quote
Old 08-10-2012, 10:04 AM   #2
Brought out of retirement Super Moderator
Reckless's Avatar
Lots of stretching and a 15mm ratchet wrench usually works
Reckless is offline   Reply With Quote
Old 08-10-2012, 12:27 PM   #3
...with cheese.
Armageddon's Avatar
Stubby wrench or ratchet works best for me.
Armageddon is offline   Reply With Quote
Old 08-10-2012, 01:32 PM   #4
Thanks guys, I'll give it a try when the rain stops. lol
Old 08-13-2012, 10:42 PM   #5
csess's Avatar
You do know you only gotta get the bolt loose right? Instead of a bolt hole its a u shaped tab....loosen bolt a little an slide bracket out. If i can get it anybody can get it....lol
csess is offline   Reply With Quote
Tags
check, cover, covers, front, head, ls1, ls1tech, removal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
