oil pan replacement
Old 08-10-2012, 03:45 PM
Silenttrouble's Avatar
Default oil pan replacement
I don't wanna tell you how but I ended up with a hole in my oil pan which dumped all my oil on the ground. So now I need to replace an oil pan I have never done this before and I know there are several seals and gaskets does anyone have or can point me to a guide on how to change the oil pan on an 01 trans am ws 6.
Old 08-10-2012, 08:04 PM
nomasterase's Avatar
its not an easy job you need to pull the motor or support it from the top and remove the k member. id go with the second route
Quick Reply: oil pan replacement
