Steering column problem - LS1TECH
Thread Tools Search this Thread
Old 08-14-2012, 12:05 AM   #1
Default Steering column problem
My steering wheel will move diagonally down if i pull lightly and also some kind of pin falls out once in a while, i have been told it can be fixed for around $150 should i pay someone to fix it, should i get a used column, do they sell new ones? what is the best way to fix this? Thanks in advance for any replies
(its a 2000 trans am)
ls1mustang00 is offline   Reply With Quote
Old 08-16-2012, 09:07 PM   #2
anybody?
Old 08-17-2012, 12:44 PM   #3
Spartan7's Avatar
Sounds like the needle bearings are falling out. You'll have to tear apart the column to find out, there is a guide on here somewhere.
Spartan7 is offline   Reply With Quote
Old 08-18-2012, 08:14 PM   #4
no, not needle bearings, but more like a pivot pin, and there is two on each side but only one falls out. And even when its in, the diagonal play is there. I just want to know what the permanent fix is
Old 08-18-2012, 09:48 PM   #5
Spartan7's Avatar
Post up a pic. You can also use this for reference:
http://shbox.com/1/steering_column_exploded.jpg
Old 08-19-2012, 04:09 PM   #6
#39 are the pins im talking about. The left one fits loosely so it falls out, but the play doesnt go away with or without the pin.
Old 09-23-2012, 08:54 PM   #7
I have the same problem, I figured out that the hole the pin goes in has elongated over time. I am planning to buy a couple of reaming bits to re-size the hole and then have a machine shop make me a new pin that will fit the larger whole based on the size of the reaming bits I can find.
From what I can tell the problem lies in the fact that there is less material on the left side as they cut some away to make room for the sliding mechanism that is part of the ignition. This seams to be why that hole deteriorates over time as you push and pound on the steering wheel.
bborchers71 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
How-To; Steering Column Repair wssix99 General Maintenance & Repairs 39 07-19-2016 08:34 AM
need an Fbody 98-02 NO PLAY OR LOOSENESS steering column Cpt.Derrek Parts Wanted 12 04-12-2015 02:34 PM
WTB Steering Column Blkdvll Parts Wanted 1 01-12-2013 01:17 PM
Dimmer switch '02 johnfin Pontiac Firebird 1967-2002 2 12-05-2012 02:18 PM
Play in column... Tilt I think TZ2884 General Maintenance & Repairs 16 05-16-2011 03:46 PM
Tags
02, 1997, 2000, assembly, chevy, column, diagram, ls1tech, parts, problem, silverado, spring, steering, tilt, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
