HELP! Symptoms of a bad TPS but no check engine light
Old 09-26-2012, 09:58 PM
unit2000ss's Avatar
Question HELP! Symptoms of a bad TPS but no check engine light
I have a 2000 Camaro ss that has all the symptoms of a bad tps but no check engine light came on. Please help
http:// http://www.buzzle.com/articl...on-sensor.html
Old 09-27-2012, 07:41 AM
Old Geezer's Avatar
So, just what are the "symptoms", U R seeing?
Have your checked the actual TPS sweep volts, etc?
Old 09-27-2012, 08:37 AM
unit2000ss's Avatar
Bucking and jerking of the car.
Idle surging of the car.
Hesitation while the car is trying to accelerate
Sudden surge in car's speed while driving on the highway.
I checked the Tps and it is working properly. Any other suggestions as to why I have those symptoms? It feels like the car is working to hard to Accelerate and jerks a little when it shifts gears. Gas mileage is worst then before. Check engine came on before, it was to replace the air pump and air pump valves but it just doesn't the same as before.Any help would be appreciated
2000 Camaro SS (automatic)
Old 03-20-2013, 09:53 PM
bodyonus's Avatar
Bump.
Old 03-21-2013, 02:23 PM
LS6427's Avatar
02 sensor(s) failing can cause these problems.
Quick Reply: HELP! Symptoms of a bad TPS but no check engine light
