(Fixed with new alternator) Flickering/Pulsating lights from pully swap?
Lights started doing this after the last build. Only mod I can see that may be guilty is the 25% power bond under drive pulley. Other mods were heads, cam, intake, and small boltons. Battery voltage from pcm reads in the 13s most of the time but sometimes when the cam starts surging then the volts go down to 12 before the car dies.
Alternator and everything was fine before the build so im thinking something with the new mods did this. Can the pulley be doing this?
I have the same mods and mine does not flicker. My camaro was doing this before my top end work, so I changed the alternator. Problem went away.
If you think the alternator is good / have tested it : I'd say check the ground strap and ensure its still intact and soundly connected. They get frail over time.
just my 2 cents
just my 2 cents
just my 2 cents
just my 2 cents
Thanks. I will check those things. I read somewhere that a4s are the ones that have the issues but not sure.
What alternator did you replace the stock one with? Did you do the big 3?
Save the manuals!
Here's a good article, which shows the tensioner marks on a Fiero. We have similar lines on our tensioners. http://myfiero.oceanmoon.com/how-to/...h-serpent-belt
It looks like mine is fine. Idk why the belt came off halfway though.
I did an under drive pulley on my car when it still had the auto tranny and the lights would flicker once in a while. What fixed it for me was doing the big 3 and swapping the alternator to a bigger one from an escalade at a junk yard.
I got a rebuilt Pro-Select out of a "Uni-Select Warehouse" and it was like $100
No big 3 here and no problems. Worked great especially when I changed all the pulleys to eliminate squeaking.
If it threw the Alt belt then you possible have a tensioner issue.
Run the car with the hood open and rev it a few times by the cable. Keep an eye on the tensioner that you have pictured above. You may see the belt start to work its way off of the pulley due to a worn assembly.
I've seen multiple LS1's at car shows with the main belt half off a pulley. General response: "ya I gutta change the tensioner, that happens"
Thanks for all the info in the thread guys. I assumed most would say big 3 and truck alternator.
Any idea what parts could die out if I keep driving like this? Does the flickering lights mean its beating up my alternator or what?
Oh and what about the overdrive alternator pulley that some guys end up buying. Is that for the problem I have?
Save the manuals!
So, your other mods may be creating a higher demand on the alt, you could have a loose wire, etc. but a new pulley should be an inexpensive thing to try. Its also free to pop the bad boy off and take it to a parts store to be tested for free. (Just take care of the exciter wire if you do that!)
