Chronic thrown serpentine belt?
So my 99 z28 keeps throwing the serp belt after i replaced a squeaky one about 2 weeks ago, after going through at least 3 belts , I decided to replace the stock idle pulley with the buick one that people on here recommend. But it has thrown it twice in the span of 15 minutes with the new pulley.
So what's next? A KAtech fixed tensioner?
None of my other pulleys have any play in them by the way.
Thanks guys!
Thanks guys!
Save the manuals!
If the old belt was fine, you shouldn't need a new tensioner.
Are you following the routing diagram on driver's side pillar? Did you check the tensioner marks to make sure you have the proper tension? Are your pulley's in good condition? Have you tried putting the old belt back on?
I replaced the old belt because it was glazed over and squeaking when the car was cold, and sadly I threw it away awhile ago.
I believe i have the proper tension on my pulley, the marks are lined up, I can post a picture of where it sits tomorrow when it's light outside.
All of my other pulleys seem to be fine, they stay in place when i pull/wiggle them.
I'm stumped!
I'm stumped!
Save the manuals!
Highly unlikely that the tensioner is bad if this started with a new belt...
Was any other piece of equipment changed with the belt? What kind of belt and part number did you purchase?
The first step is to confirm the routing with the guide on the driver's shock mount tower.
Thanks guys!
Thanks guys!
I've been trying to tell people on here for a decade that the GM tensioner is a joke.......get the Katech fixed tensioner. When I put mine on 10+ years ago I didn't change a belt until last year as preventative maintenance, the belt was still ok. It lasted 9 years. I keep in my car as a spare......
The problem with the GM tensioner, it allows the belt to bounce and stratch when you accelerate hard......this causes the belt to stretch. My 9 year old belt has not stretched at all. My new belt has my tensioner tightened down in the same exact position......belts DO NOT stretch with the Katech. AT ALL......
If a belt does not stretch....it will remain tight on day one and remain tight on year 6,7,8,9,10......
Get the Katech, you'll by a new belt every 8-10 years.
BUT....also make sure something in the entire pulley system is not becoming misaligned maybe because of a bolt thats loosening or becoming stripped.
They spent more money R&Ding a tensioner with a spring and moving parts.......when they could have just produced a LESS expensive, better part by making a fixed tensioner for us all.
But GM needs customers coming back buying new parts so they can make more cash......
Save the manuals!
This isn't true. I, like hundreds of thousands of people, have had a stock tensioner on my car for 13+ years with no problem.
Tensioners work with a spring. All springs wear out over time. If you get 10+ years out of a spring, that's great and one should:
- rejoice
- give the springs a kiss, slaute, whatever, and bury it in the back yard
- replace it
The Katech tensioner works, but it isn't for everyone. Its an old school design (probably what the doctor ordered for racers) but it comes with old school maintenance headaches. (It has to be adjusted as the belt stretches and wears.)
If the car is a daily driver and if the tensioner is worn out, (I still believe its hightly unlikely that the OP's issue is not related to the tensioner - it worked fine before the belt change.) I'd suggest replacing with a stock design and don't worry about it for another 10 years. By that time, gasoline will be outlawed and we'll all be driving electric cars, anyway.
- rejoice
- replace it
Did you even read my posts...........the belt DOES NOT STRETCH when the fixed tensioner is used.
I repeat..........NO BELT STRETCH with the fixed tensioner.
One more time.......USE A FIXED TENSIONER = NO BELT STRETCH.
The god damn belt will be 10 years old and it will have ZERO stretch.....same length as when it was new. It will NOT be longer than it was when you first bought it. The length when new will be the same as it will be after 7-8 years.
Proper tension on a belt when installed WILL NOT stretch it.....BOUNCING stretches it. The GM tensioner bounces all the time, every second the engine is on, and especially when you accelerate.
IS THAT CLEAR NOW...........hahahaha
NEWS FLASH:
BUY a fixed tensioner and then you will know its the last tensioner you will ever buy....and belts will last 10 years or longer........wow, what a hard decision this is.
A bouncing tensioner is a ****** JOKE........PERIOD.
Good luck original poster.............
Save the manuals!
- You don't have to check the belt tension as a part of routine maintenance
- 99% of people will not own these cars for longer than it takes a tensioner to wear out
I totally agree that a fixed tensioner is a good purchase if someone is racing the car or will own it for multiple decades and is in to maintaining their car.
Alas... we still don't know what kind of belt the OP is using. The problem in the thread started when the OP changed the belt. Before jumping to wild conclusions and writing a lengthy infomercial on tensioners, we should confirm the status of the belt. Having a long discussion about tensioners would be really foolish if it turns out to be the wrong size or shape of belt being used.
You have now been exposed! You work for Katech and this is bordering on spam...
All belts stretch. I suppose a well made belt with a strong structure could stretch less, but the laws of materials and physics still control. (I'm at a loss to understand how a tensioner can manipulate the physical behavior and properties of a belt.)
Because:
Because:
I replaced my belt at 90,000 mi just because it had lotsa cracks and looked rough. The belt started squeaking and rattling right away. Looking closely at the stock tensioner, I could see that the pulley wasn't running perfectly parallel to the beltway any longer. It was badly worn, but wasn't apparent until the new UN-stretched belt was on. $90 for a new GM unit and I should be good for another 100,000 mi.
As long as all other pulleys are tight and lined up...and the fixed tensioner is torqued properly, the belt CANNOT come off....period.
Call Katech......ask them if the C5R race car that the Katech tensioner was designed for.....ever throws belts. NOT POSITIVE......but just like the C5R single timing chain.....one has never ever broken.......I think its the same for the fixed tensioner......no more thrown belts.
I just hope you don't have another underlying issue.....
Because:
Because:
Like I said.....I have a mark on my tensioner. When I took my belt off after almost a decade....and put the new one on, the new one torqued to exactly the same exact mark.......
So like a fluid is not compressible for all practical purposes.....but it really is compressible to a tiny degree in reality......these belts DO NOT stretch when the fixed tensioner is used.
