Pretty Happy Today, 2 Problems Resolved.....
Old 12-03-2012, 07:55 AM
2000 TAWS6's Avatar
Default Pretty Happy Today, 2 Problems Resolved.....
I finally tracked down the P0174 code culprit. When I removed my air system, the gasket for the passenger block-off plate got damaged so I used high temp rtv. Well I guess not high enough temp, replaced with new sandwitch style gasket, problem gone.
I had to replace my front turn signal sockets, again. This time I pulled the radio any bypassed the DRL circuit for the indicators. Now they only go high wattage when the indicator is active, the low wattage still works off park/headlamps.
I was looking forward to my drive to work today!
Jon
Old 12-03-2012, 09:55 AM
buellxb12s's Avatar
Good job. I want to by pass my drl but keep ahl. How did you do yours?
Old 12-03-2012, 10:22 AM
2000 TAWS6's Avatar
The leads in the DRL module behind the radio. I shorted the input leads from the turnsignal switch to the DRL module to the leads going to the DRL/TS bulb from the DRL module. DK Blue/wht --> dark blue, Lt Blue/wht --> light blue. AHL still functions.
Jon
Quick Reply: Pretty Happy Today, 2 Problems Resolved.....
